Oops typo, fixed. it’s on the no reverse with brake. I want to use smart reverse but that seems to make the throttle worse too, while also having no brake or reverse.
settings haven’t changed, just my ability to convey information
tenka. (and before anyone rants, yeah IK the tenka acts weird for a vesc)
if you can give me a hand getting the sensors connected int he right order, or getting HFI working, or getting sensorless FOC working… honestly any of these seem like good options but I haven’t been able to figure them out on my own, the hall sensors really don’t wanna work for me (bad hall detection literally every time)
There’s nothing to it really, just set the motors to FOC and “sensorless” under the FOC tab. If you want smooth start you can search for “HFI” on the forum here to see how to tune it.
do you have any help with getting HFI working? I’m following all of the steps and threads I’m finding but things only look kinda right for one motor, the brakes are still super weak.
When swapping motors, both start acting weird, though the stuttering is happening on the same VESC side regardless of the motor.
Are you certain something here is faulty? That sounds like my worst possible outcome. I really want to hold onto the hope that the correct settings can fix this.
I’ve also tried swapping phase wires around on the MR60 plugs.
Well, HFI is very hit or miss, especially on older hardware.
Remember that in sensorless mode it’s expected that the motors might spaz out / refuse to spin before the ESC can detect their position correctly. I.e,. need to push to start, and then apply throttle and test.
Anyway, if one side of the ESC is giving you trouble, then it’s pretty likely that it’s faulty hardware. Unless you aren’t programming the sides identically or something. After watching your video, I’m pretty sure that’s an ESC issue. Are there any reported faults by any chance? Go to the terminal tab in vesc tool and type in “faults” after you reproduce that stuttering issue.
Nothing besides a weirdly usual bunch of faults after the auto-shutdown timeout (set to 30M). But that also happens on my other board with a different VESC. No faults while doing the tests or riding it. (Metr unity)
Would the tenka or the evolve gt 5055 motors be the "older hardware? (AFAICT same motors they used in the GTX and GTR)
I never got the Racerstar 5065 motors to work worth a fuck on HFI.
Try the ld_lq_diff measurement (measure_ind 0.2 in terminal) like in the video. What do you get? If it’s less than 10% of total inductance, just forget about HFI on those motors.
I gotta get the VESC to co-operate first, I reflashed stock FW and it started behaving worse after detection. sudden halting, one side not responding anymore, even louder noised when there shouldn’t be,…
and this is the 2n’d tenka after the first one blew while braking downhill. I’m so inclined to just think MassiveStator shipped me garbage twice in a row.
I’ll test with new motors but my hopes are pretty low for this VESC at this point.
