With that said, my brain was thinking of an interlocking bushing design that comes in two pieces that can be installed and removed on the 3-links without removing everything from the threaded axle.
you guys have probably already thought about it…and maybe tried it…I could see it just not working because it would squish apart while in operation.
I think its moldable using normal urethan pouring methods.
@people who run 3links @fessyfoo . How tight do you run your bushings on our 3 links? Are you able to hit the end of the trucks steering travel while just standing on the stationary board without bindings?
@zero_ads I dont have them loose. I have fund the bushing duro that give me the support I like. Then I use the rod angle and wheel base to give the amount of turning I like for the job.
@MoeStooge Do you have a list of all the black oxide fasteners on the HD 3-links? I want to replace them with something a bit more corrosion-resistant since oxide fasteners tend to start rusting just sitting in my garage.
