I would recommend figuring out what your axle setup (hardware wise) will be before buying the joints. That will dictate the large joint size you need. SRM uses ~6mm screws for the radius rods on their more robust HD 3 links so I don’t see a reason to go larger than that.
depending on your manufacturing capabilities, you have various options, however I think the most "plug and play’ soliution would just be to use the SRB bushings.
Im still curious to how these trucks steer differently to a rkp with the axle in the centre of the bushing seats.
Lets say we put a joint bearing in the bushing face and a needle bearing in the pivot cup seat so that there is no play , place both trucks at the same angle towards the ground, wouldnt that kinda be the same thing?
No, because the forces would still allow slop with that idea. Flipsky just came out with a truck that uses a spherical bearing pivot cup in an rkp if you want to check that out.
The srb nkp has a huge lever arm to resist deflection/slop. Also the bushing and center rod end bearing combination offer proper bushing utilization. Where shoving a spherical in an rkp isn’t as good in that respect.
Oversimplified but gets to the core of the advantage.
perhaps, but literally all the variables are adjustable and the least likely thing you’d do is move your pinion further out when you can move your spur gear in.
Looks like it will be close for me because I’ll be using 30mm to 44mm adapter plates.
24mm - 3.2mm (mount) - 5mm (adapter - guessing here) = 15.8mm shaft left over (0.62").
I wouldn’t get the axle all the way through the pinion, but perhaps I have enough on there. The set screw would be on the inside next to the mount plate.
Yeah that’s what I’m thinking too. I’m checking gearing options for the lacroix and the 44, and swapping the 151kv reachers onto the race board just makes more sense.
Puts both boards at 43mph average, and >500 newtons of force.
Well they sorta do. But it’s used to secure the mounting plate tor he stator. In theory you could just get. Longer m4 to replace it thru the Motor mount into the plate and the stator.
