Share your feedback + bushing recommendations for these trucks in this thread!
Link where to buy / see some videos of them in action:
I received mine a couple of days ago. I wonder if I need to add threadlocker to the bolt that holds the middle pin in place? Also I’m disappointed in the axles being shoulder-bolts instead of having a threaded end for lock-nuts
I wonder if I can buy replacement axles from Moon or Apex that will work
I had the same opinion on the axle and I did mention this to Ethan. Not sure if this will change though. I feel like this might make it much harder to swap a tire or whatever but we’ll see. This does make me unsure a to whether to put loctite on the axles. Normally I would, but with these I guess I wouldn’t?
I suppose they might be the same thread, though I don’t have any other 12mm axles lying around to test
Exactly! Tire changes become a nightmare if you have to heat the hanger up to liquify threadlocker holding the axle. Another option is to use wheel hubs where you can change the tire without unbolting the wheel from the axle, like MBS’s new hubs.
I have a set here, need to unpack and start testing.
Looking forward to trying them out.
Pavel has a video review
I also have some extended axles from Mbs, I wonder if they will fit?
They might, the thread on the mbs axles looks a little finer than on the newbee ones but you can check, would be good to know also how much axle we get with the mbs ones
Mbs use m14 fine fine thread
I actually already have them installed on one of my boards. I’m interested to hear your guys’ installation experience. Wasn’t fully painless on my end.
@Ean.esk8
Another batch coming soon?
How exactly?
Had some issues with one of the axles which wouldn’t come out anymore
also the apex clamps are pretty tight, you gotta really hammer those on; at least in my case
maybe @Boardnamics can make some 12mm axles ![]()
Just putting them together now, first impressions, they are very wide.
Couple findings from my side:
We have the bushing recommendation on the product page,
For me, im weighted 65kg
Front 2*84a tall barrel,and an 75a tall barrel on middle
Back 2*96 tall chubby and an 84 tall barrel on middle
That’s the set up i do jumping and speeding
The middle kinpin was designed insert it by reverse, but we noticed after…the baseplate kinpin holes won’t last that long as longer people changing bushings, the tolerance of the hole get biger…
We will fix the axles as well, original ideas of the shoulder bolts is people can get replacement in local, and they could choose different length.
But yeah, i will offer some replacement axles for pre-production rider lately.
Some tolerance of the old clamp i didn’t notice…but it all will be fixed in the production batch.
Went out on a ride, only swapped the front truck to Newbee. (Running Apex Air in the rear)
My impressions:
Edit: different bushings and pumping up my tires fixed the wobbles.
2 bushings only good for carving around, but if you add additional bushings, it will feel totally different.
I’m on PKPs and looking to switch the front one as well, so curious how these go for you.
Did you have the front at 30 or 35 degrees before? Turn radius better now?
I have a feeling APS formula will work much better than Krank here.
