Newbee 3links style truck
The other side of that shiny coin is called a Shill…
The guard dogs I’m speaking of are shills too.
Id support ANY 3link truck project that has these features. Especially when it looks more finished than similar stuff after 5 years. Crazy how useful actually knowing CAD is.
I spent years shilling for Brandon and telling people that the SRB is the best race platform. Then the SRB shills started lashing out at ANYTHING with a linkage and wheels on it. That pissed me off and made me take a 180° on SRB. I cannot overstate how bad it was for the sport that Brandon’s henchmen did that.
Btw thanks for the feedback you gave me privately about these trucks. I forwarded it to Ean and the changes were made pretty quickly. Very impressive how quickly we got those improved hangers.
I see a promising pattern here of rapid improvement which is why I’m “shilling”
Rods updated, new hammock should be arrive these days!
Can previous customers expect the new rods to be sent to them?
I will put the rods in stock.
Baseplate for MTB deck (5 pairs available)
I wonder if these rods will work with srb 3 links
if you get the length right then yeah. they’re the same basic parts for the rods in both designs
whats the length of srb rods.
They’re basically the same thing as SRB rods in terms of function. Left/right thread so turning the center coupler one way lengthens, other way shortens
Depends how they are set up, mine are currently around 6 inches.
also the only other down side I see to these is not being able to change the ride height. The closer the standing platform is to the axle the better.
How far is the axle currently from the top of the baseplate ?
Are these on the website? I haven’t seen them?
I’d like a pair if they are still available.
@Ean.esk8 does the axle rotation issue exist on the v1 axle?
I noticed that the v2 axle has link mounting points that are off center from the axle. I’m wondering if that is why you are having the axle movement issue.
If anyone has the v1 axle, grab a wrench and see if the axle has any movement in it.
yes it does, much less noticeable on the front than the rear.
iirc, a loose bolt magnified the issue but even after i tightened it, the rotation was still there. i can’t remember if i had the same issues with the v2 hangars and axles but the hangars weren’t square and i had to grind them down to get it to fit my gear drive adapters which fit on another hangar with the same profile
Good to know - thanks Ash.
I find the axle rotation movement perplexing. Can’t wrap my head around what allows it to happen at all.
Well considering that 3-link trucks are geometrically incapable of turning at all, I assume that this axle rotation is just a symptom of that.
/s :wink:
The articulation of the heim joints is what causes the axle rotation.
Amazing that article is like the second search result on google when you look up 3-link trucks.
“skating in never never land” or something like that?
I built a model with toothpicks that shows your trucks are IMPOSSIBLE
It’s so hilariously ignorant.
