yea i was about to say the exact thing looks kinda unstable or very loose for sure id say!
It might be a trick of the pictures, but it looks like you have steeper radius rod angles in the back than the front. You probably want the back flattened out a bit, and the front a bit steeper. Looking like a super fun build. Can’t wait to hear how it rides!
That’ll turn like a pallet jack
Got to get my board out today for the first time and I am really liking these so far. Not many miles on them yet, but first impressions are very easy to ride, turn, and stable. I have my front set at 30°, rear (reverse mounted) at 24°. 90A and 87A fat cones. Can u-turn in the street. Great first impressions @Ean.esk8
This can’t be right. The back looks steeper than the front for sure. The front looks like it can’t be much more than 10°.
Am I misunderstanding what’s going?
I think it’s the angle the photos were taken at. Based on Ethan’s diagram it does look like 30/24.
Yes like he said, it’s the angle of the pics. The front definitely has a bit more of an angle in person, and the rear is probably more pronounced because of the reverse angle.
This is the rear at 24°
Front at 30°
(Videos while build was in progress)
mannnn you guys are making me wanna get 3 links even more, that turning radius looks amazing.
Shitty video and I probably almost fell over like 8 times but I figured I’d film some circles
Video not showing up for me.
Video works for me
Must be an issue with Firefox on my Win 10 PC, it shows up in Chrome.
Ean uses an MTB setup on his 3-link videos.
I think your angle didn’t set up correctly, for zero degrees, make sure these two holes are match, also some click noise from you video, try to re-adjust the length of rods, one side of the rod must over tighten, if have the rods in appropriate length, the clicking noise will disappear.
Yeah, that’s where I have them set up currently. I had front at -10°on video. I was able to remove the clicking noise yesterday by adjusting the rods to size like you mentioned.
Honestly, I have no clue how these babies work as I have not studied Moe’s stuff and am a noob when it comes to angle nose calculations. Learning as I go.
Great work tho, feels amazing to ride them so far.
I have my front set to 30* and I am on a flat non-angled deck. This is how that looks
On the 35* angled Kaly deck, having it set the exact same way as above on the 30* hole bumps it up to 65* (baseplate is at 35* to mimic Kaly deck, end of the board would be pointing to the right side)
If you rotate it 3 more holes it would put it at 35*, which is a more normal/typical angle for that kind of deck. You can obviously have it set however you like for your riding style (I know you like carvy). You could move it 2 holes instead for 45* as well
… where did you get these CAD models
Work in progress.
Super smooth now, but not sure where I ended up in rear in terms of nose angle.
Raining cats and dogs so no test riding today.
I’ll have to wait for @AlexB to let me know through his cad work later when he gets home.
