New Lacroix Model -> Nazare
Preach!
I double checked, they did it in 2017 already, meh
Shame, we coulda shaved @Sender and put him forward for casting
Im gonna sneak a banjo ringtone on to his phone next time I see him :slight_smile:
ā€˜dualing banjos’ is the theme, it’s great I agree and everyone recognises
I made a spreadsheet when I was looking at either 10S5P or 12S4P… Trying hard to decide what to go with. 10S won out on almost every category.
Yeah exactly. I don’t understand why people have been pushing for 12S cells. Hope people have some logical/mathematical explanation than just saying current is less(which doesn’t say much by itself)
Of course on the motor side the efficiency is clear. Given the same gearing and same top speed, a 10S battery need to have a lower KV motor than when compared to 12S. But the lower KV motor will result in higher ohmic losses.
Because 12S got more of dat go juice.
I ride 10S & 12S carvers with a nearly identical gearing/wheel setup. The 12S at mid-low battery feels like the 10S at full charge.
I can and do run the numbers, but I can say from first hand riding experience- when you’re looking at larger boards like this with a 4:1~ gear ration and 175-200mm tires, 12S sorta just hits the sweet spot. The throttle/speed curve response is just a lot more snappy for this style of build.
Obviously! If you use the same motor and same gearing and then compare 10S vs 12S, 12S will obviously beat 10S because 1. It can pump current into the motors 2. You can achieve higher speed.
What’s a useful comparison is comparing 10S and 12S setup with motors with KV matched to the number of cells or an appropriate gearing ratio or both. The snappiness is just the torque speed combo which can be achieved in either setup with the right choice of KV.
Totally understand that. I guess what I’m saying is that at a certain point 10S starts to feel inadequate when you’ve ridden 12S setups and have the choice with a new build. I always consider all factors in my builds.
I can say that for me personally, a 10S 190KV 4:1 Carver on 8" wheels doesn’t have the speed to satisfy my riding needs at this point. 12S is the only option for me if I’m looking at building a new board of this style.
I think Ernesto hit quite the sweet spot with the Kaly 2.0+ configuration of 12S/190kv/4:1/200mm. They top out around 44mph which is what I’d expect of a board at that level.
Going 12S isn’t much of a cost jump either. Might as well take the extra juice.
Plus you can’t have a beast of a board and be running 10S. lol
If they put 10S on this board… They wouldn’t hear the end of it…
Right, if you already have a setup that no longer excites you, then the easiest thing to do is to bump up cells/voltage.
The thing is, when you are building a board from scratch. 12S doesn’t offer any extra juice per se. If you use the same number of cells in your pack, the juice content is the same.
You are kinda right. If you are going to consume too many watts that at 10S, the current is too much for VESC to handle then yes, you go with 12S battery, but otherwise you can safely go with 10S.
This times 10.
I’m surprised this photo did not make it here.
This needs too happen
I have to agree. Baja hasn’t been ridden all week cos I cbf doing the things that need to be done.
I’d rock that.
The lasy or the suit?
About 12S being the sweet spot… (13-14S more realistically being the ā€œceilingā€) 12S is more conservatively the most reasonable ceiling.
Is 12S really the sweet spot? Or is it just the current ceiling, making it the ideal sweet spot? Will all these FOCers or something else change the game when 20-24S can be the new top end in terms of voltage?
At that point I’d be begging for 48+t instead of 32t flywheel pulleys or sub 50kv DDs.
From a purely electrical design standpoint, we want to trend to higher voltage and build the rest of the drivetrain around that. There’s a reason ebikes and other PEVs, and full EVs run higher voltage. Curious to see what the sweet spot ends up being as we progress the tech.
From a production board design standpoint, 12S is a natural progression and hopefully a standard, but by no means a ceiling.
Tesla used 680V for a brushless motor coolant pump…so it’s definitely possible to go hella high voltage with this stuff
But probably not feasible, or safe, at eboard scale.
