So I just finished building my setup 12s2p backfire 346 wh battery with 2 torqueboard motors. I was riding today and noticrd that when i go too fast the motor just stops all the sudden and i have to jump off or if the torque gets to high same issue happens. I assumed it was because the battery max output was to low so i made the discharge current 80a inatead of the usual 60. But this time same thing happened but the unity just won’t turn on at all. Any idea whats happening and what i can do to fix it?
What’s Your motor setting?
What did you change to 80A?
pic of the wiring job?
Max motor current setting was 80a just like the max battery current. And brake was -30a just liKe the max regen current
Both max battery discharge current and max motor current
Have you tried connecting a switch or are you only using roll-to-start?
Was it ever accidentally connected to the battery with reverse polarity?
I havent tried that but ill give it a shot right now. And not sure what reverse polarit means
Reverse polarity means switching the red and black wires by accident.
You would’ve noticed reverse polarity. Big spark probably involving small amounts of soiled underpants
No that has not evee happened. And I tried using a seperate switch. Didn’t work. All that soldering for nothing
Adding a switch shouldn’t involve soldering
Connect these two pins together, labeled “MOM”, and make sure not to touch any of the other ones.
Does it turn on then?
How do I do that? Im sorry for being dumb
This is a bit concerning as well. What cells is the pack made of?
Put a piece of metal (i.e thin screwdriver) between the two to create a flow of electricity between the 2 pins. @b264 might have suggestions on what kind of tool to use
21700 cell
Which cells? 21700 doesn’t really tell me anything. P42A would allow you to safely discharge a 2p pack at 80A but I wouldn’t push many low current cells that high, degrades cell life fast
12s2p 346wh
