Flipsky just posted these on FB. What would the benefit be? I also don’t see a nut for the second kingpin. ![]()
There’s been a couple of threads about this truck, the most plausible explanation I saw was it works somewhat like the queenpin on Ronin trucks, allowing it to behave more like a channel truck by being constrained on both ends of the hangar.
A post was merged into an existing topic: New Flipsky Parallel RKP Trucks?
The second one would be a queenpin, like the Ronin trucks have.
Though the Ronin queenpin doesn’t have a bushing.
Those crossbar supports look like they’re shaped like actual spoilers lol
What’s the benefit? Stability?
On Ronins, I believe it’s so the bushings aren’t carrying the weight and are only used for lean, like channel trucks.
But this design with a bushing would not work the same way, I don’t think? Not sure since I can’t see the details, and don’t have one.
Every time I start thinking I have trucks figured out, the rabbit hole gets deeper.![]()
Thank you!
why do I see the shadow of designs from like 5 other trucks merged into one
Right? I see a bit of Hoyt, a bit of dickyho, a bit of boardnamics…
looks pretty sweet, more competition always good
I have exacly the same ![]()
I believe @BillGordon has that covered.
Its planted firmly, yet unstable atop the riding platform.
Its basically a valkyrie voxter copy with an extra bushing. The bushing thats inline with or behind the axle would have a dowel pin since the other roadside bushing and pivot cup holds the hangar in place like a normal truck (albeit with less pressure since its so close to the pivot cup), and due to the placement of this bushing being further away from the pivot cup it more effectively prevents side to side slop of the hangar. This normally gives a more “direct” steering feel and a bit more stability and consistency in turns because the hangar isn’t slopping around as much. They also seem to be using flat washers which is honestly surprising (and good). So some chinese companies appear to be learning from high end US brands and improving quite rapidly
They’re out!
Axles look pretty short, 13mm diameter at the end of the hanger is a weird size for finding pulley bearings for I think.
they look so heavy ![]()
Has anyone tried the Valkyrie Voxter trucks? I wonder it this kind of offset technology could be incorporated into a TKP.
I would KILL to be a fly on the wall in their meetings.
Like did they ask a single person for input?
Ironic considering your ROSA trucks also suffer from short axles ![]()
