Could just be a 10mm shaft spun down to 8mm outside the can. I’ve seen that plenty.
(point being, the 8mm and 10mm shaft could use the same bearings)
Maximizing the size of the balls inside the bearings will increase the longevity
We using two bearings and is fully sealed high quality german bearing.
For now we just make one kv per motor.
bookmarked!! Thanks again
Most outrunners have 3 bearings?
Bigger bearings are still better though!?
Most have just single bearing at front of shaft.
Wll you have 1 large bearing to support the can? Prevent it from touching the stator? (Like Maytech 6880 and 6396 or SK3)
Does it need it for such a small motor?
For a small motor, maybe not, but I’ve had a lot of my motors eventually have the can scrape against the stator, and I dont’ like it.
I share design soon. I think friend can like this motor
So Jeff how much would it cost to do a run of these with titanium cans l asking for a friend
Which kind of titanium you want. I think is overkill. 4mm thick aluminium is very strong.
It’s overkill but some folks would love to have a set with that heat treated oil slick finish.
I think can do but would be too expensive maybe $250 each motor.
Oof yeah I mean that’s not crazy considering what some of us are willing to pay but a bit steep for a group buy, is it possible to do like a coating with grade 5?
We can do many coatings, but which kinda of Ti you wanting? Because material is expensive would need to making a big number.
Yeah I don’t think it’s practical unless enough people on here want it. Would look very nice though
