Hello friends. We are preparing for make two new motor for friends. Is two size motor:
5050 - 160kv - 8mm shaft
6050 - 140kv - 10mm shaft
This motor is design for take abuse and have many power for size. We use special magnet for curve to motor and have 4mm thick motor material so rock and bump cannot making problem.
Motor shaft is make by reinforce steel and have multiple bearing for support. Motor is seal for dust and dirt.
For shaft we can using keyway.
It have sensor which is pot for protect for long term using which can connect direct for neoBOX and Other. Motor is use 4.5mm plug.
I think the NeoBox is overkill for the motors RideNeo creates so far…the V4 should do 60 motor amps but these sized motors shouldn’t do much more than 30 motor amps
So caliber trucks? Not a fan. At all.
Would be better if they just share the mounting patterns almost all esk8 drives use.
Then people can use them with whatever belt, chain or geardrives they already have rather than needing all new mounts
