Hi guys,I just find that there is a new look 6374 motor in Flipsky store.
Anyone who has tried this? What’s the difference with the previous 6374?
As I can see , the color is special,which definitely makes board sick:
Yeah double the price of their standard motor and more expensive then a Tb one
Is the rotor (magnet can) keyed to the shaft with a 3mm key?
Are the magnets affixed with epoxy that’s flush to the magnet surface? (“battle hardened”)
Do you have a photo of the inside?
Are the bearings ceramic?
This is the best info I can dig up.
Yeah, this one is cheaper a lot. Thanks.
It looks like the rotor is held on only by two tiny grubscrews, which is super lame.
Unless they have drilled the shaft and there is a roll pin or something in there, but you’d think they would mention that if it were the case.
No doubt this will come loose over time.
Theyre good and no loose shafts
Installing sensors was a pain in the ass.
@b264 check discord
The set screws are loctited, I cant removed them. I am guessing there is a flat edge like on TB motors.
very curvy magnets
looks like the magnets are the wrong way around maybe?
Smoother ride at the cost of higher kv and a having to bodge the hall sensors to make them work. The sensors need extend into the stator to work properly. Or the can needs to be seated further down.
Did you see the latest maytechs have what looks like fully battle hardened can and a key to locate the shaft on the can?
They overheat like crazy too :).
Do they not come with sensors? Listing on Flipsky says they do. Overall impressions of the motors yet?
No visible signs of epoxy Between the magnets. Too clean is no good
the ones shipped from Flipsky should have sensors.
If there were, the motor would probably run aground xD. I’ve been running these forever in my build without issues. They have pretty decent retaining rings in them. Probably not the best idea to put them in an offroad build though.
Has anyone in the US bought anything from flipsky recently? I am wondering what shipping times are looking like
I would not pay that for a Flipsky motor lol. The color scheme is also not as “classy looking” imo
@stan
you tested these out right?
