Why not? I had 12s8p NESE in DS evo enclosure.
The eBoosted DS enclosure? I suppose you had to use a thick gasket?
5mm maybe. But thickness doesnât change from 7p to 8p
It doesnât but the enclosure gets slightly narrower towards the bottom so while youâd be able to put 7P all the way down, the same is not necessarily true for 8P.
UPDATE:
26650 hardware is coming mid December.
There will be another winter sale for a month as usual.
I will start selling V2 modules which are smaller.
I will have some V1 old stock at half price.
Now i need to hope all this pandemic nonsense does not affect me too much and i can deliver on time
Anyone here with VR? Testing out platform for people without 3D printers to have my modules looked at in VR or XR
Does anyone have the link for vented 21700 V2 modules? I only found the non-venting ones on thingiverse.
Edit: found it
https://cults3d.com/en/users/18650/creations
21700 and 26650 hardware and modules will be available at the end of December. 18650 ships as usual.
Shipping will incur delays due to Christmas and pandemic so bear that in mind when ordering.
Thank you for support
is any bus bar alternative solution?
braided cable?
https://za.rs-online.com/web/p/braided-wire/0365543/
From my perspective no. I designed enclosures and tabs to fit one another, have best possible contact area and pressure to keep cells snug.
There are other systems on forum using braids.but you can do whatever you want and test for yourself
On the same subject, does anyone seen a topic on wifly braded system?
I was gona check it out how he is doing, on the progress but cant seem to find itâŚ
Didnât you used to have precut tabs in specific P length in your store?
Yeah, I have a few braided copper packs w/ winflyâs compression packs. They need to be under even, sturdy compression (ideally like in a haya or the old-style, double-cutout hummie), and assembly isnât nearly as fool-proof. Having said that, I really like my packs, and they were balls-cheap to put together, but I have some NESE packs that are also great and will be buying some more hw now that theyâve got 26mm size.
Is the 26mm hardware hiding on your site somewhere?
Hi. Yes, i did had sets but there was too many products and variations and with 26650 additionally it will be nightmare⌠There will be a revision on prices and they will get cheaper slightly and there will be a paid option to request tabs to be precut.
@RyEnd, the 26650 hardware is made, just need to get logistics sorted out.
I am currently with the COVID so moving slowly, as this flu is weird
Here is the photo of the new 26650:
Cause of this delay, people who will contact me before 2nd of January will get their 21% winter discount anyway as i could not manage supply earlier. Just write to agnius@1865o.com, describe what you will need and will get it sorted.
Promotion extended till 2021.01.31
Parts are almost here.
Are those 21700 or 18650 modules?
Has anyone had any sucess fitting molicel p42a cells into the NESE 21700 modules?
18650
