I’ve been lurking for a while and have learned a lot about DIY builds. I’m not ready to start from scratch, but want to but a decent complete and modify.
Anyway, I found a Bioboards Radium for sale with the following specs.
Deck: Landy Yachtz
Motors: 2x Maytech 6374 170Kv 3500W
Pulley: 17T+40T
Top speed: 58-60km/h
Battery: 12s4p 30Q+ in parrallel to Boosted xr13s2p.
Mount: Tourqueboard 63 Mounts
Wheels: Tourqueboard 110mm
VESC: Focbox Unity
Trucks: TB218
Remote: Flipsky VX2 Pro
I’m hoping to swap out of the 36 Switchblade to a slight bigger board with a double stacked enclosure. The gear drive was swapped out for a belt drive. So I’ll be looking to fix that courtesy of EToxx’s gear drive kits
Enclosure looks to be a DIY (see pictures) and I’m not sure how easy it will be to take the internals out without causing damage.
Any suggestions on decks and also is there anything that I should be aware of when swapping over?
I’m asking for picture of inside the enclosure to see what kind of state it’s in, I’ll post once they arrive.
Definitely not a Bioboards Radium(see below), I wouldn’t buy from this guy as he seems to be spouting nonsense.
[Edit] looking closer there is a possibility, but why make them changes.
@mackann Bioboards killer right here. this surely puts the plutonium to shame right? right?
@monkeysapien Bioboards only use @3DServisas Parts for the trucks and gears, and the enclosures are made by @eBoosted i beleive which certainly don’t look like that.
And as @mmaner pointed out
very big oof. 13s on a unity is no no unless you are a maniac like @longhairedboy
Share a link where you found this ‘‘great deal’’, because this price isn’t too bad but i wouldn’t trust the seller on my life with this crap
I asked the guy selling if he made the enclosure and he said that was how he bought it. The deck didn’t look like the Switchblades used I had seen on other Radiums which I couldn’t understand (still a lot more to learn).
I found it on Facebook in one of the buy/sell esk8 groups.
Boosted battery is lifepo4, cells have different voltage ranges than li ion. And then again 52v charger, overcharging both batteries? I am really not sure how that works
How has that board not caught on fire with such an extreme difference of voltages??
Might as well add a few TURNIGY packs in there. Not like he cares about selling deadly crap to people
But’ I’d say… if someone took the basic shape of a claw-foot cast-iron bathtub and had a rough try at it scaled to esk8 size… added herbs and ineptness…
