I got a raptor 2.1 off of my friend. I was going to use the components for my DIY project. BUT.
When i try to connect focboxes to pc via usb cable, it doesn’t show up. I checked online. It may be bricked but i couldn’t find the solution. And tried multiple usb cables.
There are charge cables and “sync” or “data” cables. There isn’t a way to tell them apart from the outside (unless checking pin continuity or X-ray imaging) so you have to be extra sure you’re using a data cable. I’d buy a new cable specifically marked as Data.
or just don’t keep any charge cable around data cable has to have those power pins, that makes life so much easier if there is only one “type” of cable
why not just have all data cable to save ur time? I know sometime certain device comes with those power only cable, but there is really no point to keep em around
