But stylish
It’s been done before, plenty of laptops used USB PD which can push a lot of amps, as well as someone used a magsafe connector to charge before too lol
Jaykay uses type c and exway uses magsafe, both are actually unique in their own ways
Usb c is rated up to 20V@5A=100W
21s1p p42A charge 50.4@4.2A=211.68W
So charges just under 1/2 speed - the buck converter efficiency
It’s boost, not buck. Boost = up voltage down current, buck is downvoltage, same current usually
And a buck-boost is veritable
Yes lol
I was waiting for someone to say this lol
did some weird firmware thing and kept cutting out. Might have been the battery, I will try a new batt later today
3.62, you’ll never have problems.
Yeah, I could consider hub motors. I am doing my own build because I have a good bit of parts at home already so will be cheaper than a backfire mini or something.
ok I will try it. What vesc tool version is that?
okay yeah, that is usually what I use as recommended by mark
I’m using this one on Karam’s recommendation and I haven’t had any issues either since installing. Smart reverse on it works fine too if you are using a UART remote
Yeah I second this advice, I had to switch to 50mm motor on the Venom Magnums because clearance was just too tight with 63mm motor
What battery you re going to use and is it plane-safe?
12s1p p42a
Not airplane friendly
Yeah but 2x 6s1p P42A is, about 89Wh each. You could do 2 seperate 6s BMSs and charge each block at 100W as long as you seperate them, I’d look into using the loop key between the 2 blocks and have it covere the 2 USB ports
Lol yeah, that was the original plan. Just don’t want to deal with 2 bms and the enclosure isn’t gunna be easy to remove.
