Yo! I am currently working on a board that is super light and portable. I need some suggestions on some parts. I have a lot of the same goals as @kntzn 10 pound commuter.
Desired Specs:
22+ mph
8+ miles
under 12 lbs
under 28 inches long
USB C charging
Decently powerful single drive
Focbox from @KaramQ if I can get it to work properly
Caliber 2 trucks
I am open to suggestions for everything else
I am looking for a single drive motor that has a good balance between weight and performance. I currently have an old maytech 6374 that I could use, but I thought someone might know a better option.
Also any recommendations for deck/enclosure? Again, I want something light, and under 28.5 inches. Enclosure wise, I might just 3d print. I have been looking at the 121c orbiter, but it is a bit expensive for such a low cost build. LMK if you have any genius ideas that I missed.
Wheels wise…I am thinking 85mm cags, 80mm kegs, or 83mm abec clones. I already have the cags and the clones, but I only have pulleys for the clones.
Shoutout to the shortboard master @b264 for talking with me about ideas for this board.
Also thanks to @PrivacyDoctor to helping with the type c charging
If you’re looking for an Aileron, i have a few new but scuffed from shipping ones. $80 USD + shipping. There are 6 pre drilled holes for our enclosures tho.
Did you think about hub motors? You can’t max out a 63xx motor with an 1P battery anyway. Honestly I would suggest you do go with a dual hub motor setup. You also don’t need a VESC in an 1P setup.
This is would I would do:
Deck: choose what ever deck you like.
Battery: 12S1P P42A is a great power to weight to size ratio
Power output: 43.2Vx30A=1296W
Capacity 43.2Vx4.2Ah=181Wh results in ~10 miles of range
Size: 12x21mm=252mm results in 252x700x21mm total pack size
Weight: 12x70g=840g
Motors: Dual hub motors like MT
Truck rear: MT Caliber 2 clone
Truck front: proper Caliber 2
ESC: Lingyi or HW (would personally take LY)
Remote: LY or HW display remote (again would take LY)
BMS: 12S Daly
