Even with a riser and mounting the truck one set of holes further, getting wheel-bite with 110mm wheels with 220mm caliber trucks. (Would be the same with 100mm wheels too)
Then I tried Surf Rodz RKP:
Getting wheelbite only on hard turns, and I bet it would be a non-issue if you mounted the truck 1 set of holes further / used 100mm wheels / had a riser pad.
Go for the Boas if you want as much range as possible, but even 78A TB 110mm wheels make a noticeable difference on cobblestone / pedestrian sidewalk bumps.
Also, I don’t think charging the cells at 2A will make any impact to cell life compared to regular abuse when riding the board and braking with regen.
