why do you need it not balancing
Got it, wont cheap out on wires, for the 27$ version it doesnt come with app, but planning to do a pro version soon
it will be coated in Urethane, so it has some basic weather proof
what about a tiny screen that has a chip in it and it shows voltages on the screen wirelessly
like something something on your keychain that tells group voltage
balancing Waste energy, creates unwanted heat, cells voltage goes up then down then after balance charging their same voltage again
Iâd just like the option just to monitor each cell then any problems replace it.
Think for this application itâs safe not to balance, and if there is a fault, then youâve lost your brakes :;(
if it doesnât balance, whatâs the point of BMS anyways lol
A charge only bms doesnât have any influence on your brakes.
Exactly, think itâs better just to monitor voltages, as someone else said better to have a deck on fire
with brakes, than a deck on fire without brakes
Ok didnât see itâs just a charge only
Not sure if youâre following here, or if Iâm just so out of the loop that Iâm not following your logic. If youâre bypassing (EG: Directly Connecting the Battery to the ESC) the BMS, there is no concern that the BMS would ever âdisconnectâ or âstopâ current flow to the ESC.
Edit: you posted just as I posted ![]()
Can you possibly code no balancing? Iâd have one
think you are definitely onto something if its low cost also
if you write it in pctool the have the balance begin at 4.5v you should have no balance
Perfect can you put me down for one thank you.
Why the heck do you even want a BMS if it wonât even balance charge? Whatâs the point of it? There are plenty of super cheap BMS (Iâm talking 5-7$) that will just stop charging when one cell is over 4,25V
Just get one of theses:
I can only say that none of the battery builders would advise such a super dumb BMS with no balancing capabilities
I have one of those already thats the one I use, like I said I just wanted to monitor each cell.
Iâve done at least 50 cycles and it stays very balanced check each cell when half voltage and they are very close what also helps is that Iâve got a 8p battery.
Lots of people just balance charge only no BMS
I get the argument of not wanting a Bms to save space and make it more simple. But if you already have a balance capable bms installed I donât see the reason to not use it over an external balance Charger.
Itâs not really a BMS it says BMS but itâs not. It does no balancing it just balance charges. Like I said I was after something that monitors voltages and balance charges only
most BMS only balance when charging anyway.
This nano16s BMS balance charges only.
I think you donât understand this properly.
This BMS balances the cells when charging. This is what most BMSâs do and itâs safe this way.
No balancing at all is bad. The BMS shuts off the charging when one cell is over 4,25V.
Over time your cells age and the difference in their internal resistance will unbalance them over time. When the BMS stops charging at 4,25V at one cell the others may only be at 4V for example. Then your pack wonât be fully charged.
This unbalance gets worse every cycle untill some of your p-groups are over discharged and wonât charge anymore
