Just wanted to share my first ‘DIY’ attempt. I felt this wasn’t complete DIY so I kept it in the general discussion. I took an eBay board with what I thought had OK specs (90mm wheels, 42v, 5.2ah, dual belt motors, nice looking enclosure) and retrofitted this setup to my trusty evo. I’ve hit 22mph and estimate 7-8 miles of range (haven’t run it out yet). I have another battery and enclosure with the same specs above that I plan to add in parallel to increase range and reduce sag. Having a blast. Hopefully purchasing a build kit board over Black Friday.
Congrats on your first build! Welcome to the DIY club.
You really want to look into sealing that enormous gap between the enclosure and the deck though. You won’t want water or random conductive parts flying in.
@avX it’s got a ‘seal’ on top of the metal enclosure so no water can leak in (even if the enclosure isn’t tight to the board). Supposedly it was ‘ip54’ waterproof or something like that? I’m still thinking about running a bead of glue or something to really seal it up, but I want to add the second enclosure and do the wiring before that.
Also, you might want to change the way you’re routing those motor wires into your enclosure. Your motors are going to eat those sleeves everytime you turn your board (when your truck leans)
Mounted the second enclosure and battery, bent the enclosure to match the rear curvature of the board. I now have two 5.2ah 36v batteries in parallel, can’t wait to see how much range I get!
