I just took the board out. Full speed for most of the ride. 5.4 miles and the battery showed 36.6 volts when I got back in (not sure what that translates to in range). My average speed was 20+mph. Also got my old helmet out
low rider!
Dont know how i missed this, but looks great, especially for a first build. Well done!
One of my motor mounts came loose today so I completely disassembled and found out I could do a reverse setup (wasn’t really certain If these were throw away setups or If they could be tweaked/modded). I should be able to remove a riser now if I’d like. I’ll post more pics when it’s back together.
Sanded the deck down and stained it ‘ebony’. Also installed thread inserts and filled holes from my previous enclosure mounting.
The reverse mount didn’t work out, but I was able to adjust to a different angle on the mounts to allow the rear truck to have full movement.
