Thanks! What wheel pulleys are you using?
Do you get a lot of punch with that ratio? Iām on 15/44
I canāt full throttle from a start but I could use a bit more on really steep dirt hills. Enough torque that I havenāt bought other pulleys
What batt and motor max amps do you have set?
Iām using roughly the same ratio with 150kvās at very low power settings and donāt get that umpfh Iād need for wheelies because Iām already at risk of falling off under acceleration.
Battery at 95A, motors at 60A normally. I kicked it up to 80A on the motors now thatās its been colder.
@DEEIF You can try mine next time you come to the outlaw race. 1:6.25 and 130kv or my buddyās 1:5 and 150kv.
I use a 12s6p and use about 12wh/km on my MTB. Longest trip I did is just 23km but still had plenty of range
Iāve been lucky to get down to 21wh/mi mixed terrain but flat and going 15mph ish.
Itās no fun riding that economically though.
Damn! Thanks! Are you gonna be at the next one on Nov 3?
Iām around 12-15wh/mi on roads and light trails, but proper off road stuff no chance, not for a guy of my weight. I ride 10S8P though so
Thats quite efficient, I wonder what I would get with helical geardrives Whats your average range?
Iāve only rinsed the battery once, we did 25 miles but it was full throttle the whole way on concrete. I had some left but cant remember what. I think 30 miles would be achievable at reasonable power levels
What you guys think for runnin a 12s5p for an Emtbā¦ Mostly street and rides with only a 15-25mph avgā¦ I only weigh 100 pounds
I think that would be a nice battery size bro
That should get you some good range even if youāre blasting it.
Yayā¦ Iām hoping for 20ish miles which seems acceptable as I get 13wh/mile on my 12s4p single wheel drive with a ton of hillsā¦ (9wh/km)
Nice! Ive yet to run my pack fully dry from being charged up I think my legs would give out first tbh xD Thinking of making a concave to make it more comfy or maybe get some better shoes idk. A concave mod would perhabs be a cool video idea if you are interested in that
I have it logged as a video idea, I have the printer to do it but not sure if I would personally like it as I wear full bindings with heels when I am tooling around in the woodsā¦ kinda makes concave mods a bit pointless I guess?
What pressure do you run on tires? I think this is the main culprit of people getting poor efficiency, when I tested my 6.5" tires I pumped them as much as I could with a hand pump, and consumed just 1~2 Wh/km more than with 85mm wheels
