more shaft wear spotted in the n00b thread.
I think this fix of applying loctite 680 is holding up fairly well. It did quiet down and then get noisier after the fix. but it hasn’t continued to get worse and subjectively I think it’s doing better than before the fix.
applied to both bearing on gear side. and the outer bell bearing that this nazaré motor has.
not super science. but worth an update.
I find the stuff generally holds really well unless u don’t clean the surfaces well before applying.
Acetone or alcohol
Someone somewhere on this site posted a pic of how they’d …knarled their axle so the bearing had an interference fit. He’d done it on the hanger axle so the wheel bearings were solid and didn’t rattle. I forgot the the term and it’s not knarling. Something like that. Forming ridges on the axle increasing its diameter slightly. Nicer than glue and permanent
Knurling. sounds gnarly. ![]()
Looks like an easy solution for any loose fit bearings.
Galling maybe
Just another hypothesis
I think it has to do with the bearings tolerances. I replaced both bearings from my motors, one of them had a bit of wear, and in both the external face bearing was in way too tight, to the point that the new bearings weren’t spinning freely, I machined a bit the bearing seat until if was a nice fit
Both of the face bearings were completely destroyed, the two internal ones were without line but the balls were good, and in them the tolerances were much better
wanted to take apart one of these motor’s that I loctited to inspect it (for other reasons) it was a bit of a pain in the butt. with the bearings coming out of their seats even though I tried getting heat to them.
Hey look those boosted motor issues, some of them were exactly this motor shaft wear.
from this video. pretty fun watch.
in the video the guy ended up cutting the pulley off.
makes his own replacement shaft. and replaces the bearings.
long bump, for posterity,
at some point after all this. I learned a lot of the buzzing bees noise with these types of motors was the can rattling against this outer bearing.
I resorted to putting a bit of kapton tape on them as a “short term fix” I think i did three small segments 60° apart and it totally solved the problem. until the point I switched out to some reachers, and then also started riding other boards a lot more.
The play allowing that to happen could still be the motor shaft wear. but… the noise was definitely the can against this outer bearing.
