Motor sensor repair guides/thread?
I cant say how long ive been riding.like.this but probably close to a year now… But got a set of 6374 maytechs a while back and at some point during normal riding and swapping this and that I started getting weird results from the unity during detection. So for a while now ive been running 1 sensored and 1 non but its still not as smooth as when u have 2 working in foc.
Any thoughts, insights and/or link to making my 1 motor while again…is it even worth the time?
Gave up on sensors, hfi is just as good
What’s the highest motor current you’ve hit running it and what motor u use? I heard it disconnects with high enough current.
reseat your sensor cable connector in the unity or you have an incomplete circuit…
https://metr.at/r/ByNMe 44 amps
I see u hitting way higher. I see 83 at least. U don’t lose positioning anyway I guess. Is that data two motors or one? Im guessing two from what u say.
I have two 6378(of I remember correctly). Sensors is only for low speed anyways, it’s configurable and default is 3000rpm
Thanks. Is the data from two or one motors? And ur using the vedder positioning thing not sensors right?
I think it’s an average value from two motors, and yes, vedders hfi mode
I would go through and open up the motor to check the connections from the jst plug till the hall sensors. Maybe just one wire broke or doesn’t seat right in the jst plug.
Don’t think it’s the case of the unity Interface, but to be sure I would swap the working motor to the other side and see if the motor detection run through without faults.
So if i go back to an older thread of mine where the actual issue I had ended up being a phase wire connector came loose on the unity side. Its been from this time where the issue presented itself.
Across 2 unities the problem persists and def follows 1 particular motor.
