Looking for 2x 15mm 5m 15t motor pulleys with 10mm bore. Seems like those are hard to find, anyone got some spares?
Let me check later today
Are you prejudice against more teeth? Or specifically 15t only?
16t would be okay too.
Fuck me 90$ for 2 pulleys, hell naw
It’s LaCroix and it’s titanium LoL.z
I’m surprised it’s only $90
Yo, I got some 16s if you want: [WTS-US] Deck Wings / Motor Pulleyz / MTB Bearings
Aw, you’re in Germany. GL!
Thanks, here’s to hoping that someone still shows up.
Got mine (8 mm ones, but they do have 10 mm as well) from this seller on aliexpress: POWGE HTD 5M 15 Teeth Synchronous Timing Pulley Bore 5/6/6.35/7/8/10mm for Width 15/20mm HTD5M Belt gear 15 5M 15 AF 15Teeth 15T|pulley bore|timing pulley boretiming pulley - AliExpress
took literally 2 months for them to arrive, but other than that it’s all good
(edit: spelling error)
Thanks, but those are aluminium, how do they hold up for you? For me even steel ones get used up.
I haven’t really gotten around to use them yet, so I don’t know how well they will last, but I figured at least they’ll probably last longer than plastic ones
But given that steel is harder than aluminium, I believe the aluminium ones will get worn down faster. An option however is to just buy a bunch of these since it’s only like $5 each and just change them out as they go.
Anyways, I’ll let you know if I have any problems with them
Not surprised you can only buy it in rainbow. LoL.z
Thanks!
