I updated my unity after not using it for a long time, now everytime the board cycles power I have to re run the motor directions setup. 1 motor needs to be inverted and the VESC always seems to forget. Anybody else experiencing this issue?
Changing around the phase wires is a last resort option, please don’t suggest it.
I notice it only happens when I’m in a hurry or showing off my board to someone though . The esc will fully forget it’s settings and go back to the beginning and I have to reprogram it.
For me, it will only happen once every other month or so. Seems like you have a severe case of UPBD.
I actually updated from unity 23.46 to vesc 5.2 FW just to be able to save configurations because of this issue. With 5.2 FW, I was at least able to immediately restore configuration by saving my configs instead of spending 10 minutes running detections and changing the few random other parameters.
This was happening with my xenith, SPECIFICALLY when I ran my board to empty. Then one day it just stopped doing that. Haven’t got a freaking clue why.
Personally, I felt like it had something to do with letting my board auto timeout. The first 2 times it forgot its existence, I’m fairly confident it auto timed out. The third time was a maybe. The 4th time I’m pretty sure it was turned off normally.
I don’t think I’ve ever once used the button to turn mine off, so that could be involved. For me, I had to rerun detection n whatnot after every charge. I assume based on that that it was an issue with draining my battery all the way down. Sounds like general gremlins.
