I just bought a used “custom” board . Pretty sure I got ripped off. Battery is junk. Has a drop through board but the trucks are not mounted dropped. The base is minutes on the bottom of the board. Figured I would get some tb 218 trucks to drop thru. Replace the battery. I am new to eskate … my issue now is that the motor comes loose after riding . It comes loose at the truck. I have tightened all four bolts and they still come loose . I have not used loctite yet. I was reading something about the can? I am assuming this is the outer shell of the motor that spins? So possibly the motor is unbalanced and creating too much vibration for the bolts to hold the trucks? Or maybe the truck is not made for eskate? Any ideas?
Thanks
Well, the battery is a whole different issue… But the truck issue is easily fixed.
Go on ebay / the ‘for sale’ area here and find some caliber 2s with blasplate.
Swap out that entire back truck with the caliber 2, setup the drive train again and you should be all set.
The main difference between the trucks you have and the ones you want is the shape of the hanger.
The caliber 2 is quite square/angular, giving the mount room to hold on to the truck. While the Paris clone is quite rounded, giving no room for your clamp to do it’s buisness
I had paid for two metroboards and the guy said he couldn’t mail them after I explained how he just cancelled the sale and refunded the money. Then I won and paid for another custom board and they cancelled it (wanted more money) . So when I saw this it said 30 mph and 30 mile range I saw tb and thought it would be a good deal
