How much weight were you at in the backpack? I started working on a SPIM08HP pack (12s1p [what i had laying around]) which comes out to 8.5~ pounds, I’d hazard the whole thing with the controllers, battery and the weight of the backpack was something near 15, even that was rather shockingly heavy feeling.
Edit: just weighed it, 14.2 pounds so pretty close
Try 30 pounds for size. That’s 23 pounds for the 20S1P 15Ah Headway 40152S battery pack alone, and the rest for ESCs, AS, laptop and related everyday needs.
Gross; My knees are bad enough, adding another 15 pounds to my kit may be enough to throw them over the edge
This (the weight) is probably subconsciously the reason why I just couldn’t convince myself to go with the LiFePo4 batteries and will likely end up picking up some P42’s. I also dont commute with my board at all, so bringing my laptop with me and any other “EDC” items really isn’t a concern.
Still havent had a chance to test the board out yet, soon as I plugged in my pack my SuperFOCer6.8 blew up . I did expect to revisit the top/under deck mount idea after getting a feel for the back-mount but maybe that’s something I should start sooner rather than later.
Maybe someone will start working on an internal battery MTB Deck that can be trusted. I just cant get over how clean the board looks without the huge pack in the middle.
Yeah thats something to take into consideration that I didnt really think about. With SC 100S/D coming around the corning, packs will start getting larger and an integrated deck may not be physically possible?
I could just vertically stack the batteries under the board and put risers on the trucks. Would maximise space usage and I could make a Lonestar-esque enclosure to keep it covered. The batteries are only 6.5cm long.
I’ll go play around with config and come back to y’all, might need to call in some @glyphiks enclosure wizardry.
