50x25mm aluminium L-section back to back forming a T-section, about 150mm long, with 100mm of the “T” cut off. The remaining 50x50mm “T” is the bit that pokes out, and the 150mm lies flat on top of the battery pack.
Then the ESCs get mounted on either side of the 150mm piece, and on the 50x50mm I put a CPU heatsink, might add a cooling fan later too.
Rated for 4032W each. Max Amps on my last run was 94.3A at 57.0V for one motor and 89.8A for the other, so guess I was over by about 1100W for a short period of time.
Do you think I should be looking at 6396’s or 6380’s?
Not necessarily concerned for the motors, more so pushing that much current at that voltage. Doesn’t that antispark only have a 60a fuse? And your settings are at 100 battery amps per side
I don’t think the escs should be getting that hot. I also don’t think you need that much current.
Okay, now you’re talking sense to me. So it’s a 60A fuse, but apparently only pops at 95A (right @Blasto?), and I only drew max 63.6A on my last run. Battery current is the total, not per side IIRC.
In my mind, going from your screenshot above, each motor should be getting 100A battery current.what happens if you set one motor to 50 and one to 100? Do you get 75 over both of them?
