A decent performer, equal to the Samsung 50E3. As for all of the 5000mAh 21700’s I recommend staying below 10A to increase performance, increase cycle life, and to reduce risk.
Damn… didn’t expect this… Are all of your findings on GitHub? Or some central location? Or do you have your own site yet? From what I have seen the other BAK you have tested have been pretty up to par as well right?
They are a huge, and legit, manufacturing company and have been around for at least 15 years IIRC. They’re big in Asia but the rest of the world is “discovering” them now that so many other cells are hard to get.
BAK and DLG make pretty good cells. Both have 30Q contenders, but from what I’ve heard BAK’s is very good but not quite, and DLGs has a poor cycle life.
I actually recently got a few hundred DLG 3000mah 6.6A cells for my own scooters/small stuff, and initial tests say they were great value. I got them from Fogstar, a pin damaged them (I think on their testing rig)
I actually emailed them asking if they had spare P42A cells, because I was short a few, they didn’t but they did have these. They don’t stock B-Stock, I think these were damaged by their testing machines or maybe in shipping.
The P42As have dents on the edge of the bottom, as they avoid the internal spot weld I’m pretty happy using them.
That’s just an amp below the rating I gave them and is very hard use for these cells, but it won’t damage them a lot. They’re best at 5A-7A and lower for good efficiency but 9A isn’t a disaster. But it is about where you really start seeing a lot of sag and loss of range.
A 9P of these will blow away a 10P of 30Q’s though.
I don;t have a Metr or Robogotchi to see what i actually pull on the Flux.
but I doubt i actually pull 80 amps.
so I wonder if i could just set it at 65 amps and be golden…
there is not a better 21700 cell out there capacity wise correct for our application?
i woudl also consider the 50E, but not sure if those are ever availalbe.
Wondering the same. My hub motor only pulls 20A, but unless I’m going at max speed, that’s less than 20A battery draw. So less than 10A per cell. These seem pretty good for that use case
I actually recently did a 12s8p of these cells, in a pneumatic build. One charge did 48 miles, next charge did 53 miles. I think there was a bit more in the tank, but it’s performing well.
I got two cases of these, and they’ll also be going into another couple of portable chargers for Onewheels and stuff.
