Test Report Summary: This tested out as a pretty good performing 20A cell. Except for a slight dip in voltage at the start it is essentially equal in performance to the Samsung 25R5 down to about 3.1V.
Photos, Graphs, and Ratings Graphic: Imgur: The magic of the Internet
BAK is a huge China manufacturer and cells from companies like these will become more important as cells from Samsung, Murata, LG, etc., become harder and harder to buy.
The datasheet lists a 30A “max continuous discharge current” but also lists a 75°C maximum cell temperature limit and a 3.0V voltage limit.
Since this cell would reach about 90°C when discharged at 30A this confirms it is a “temperature limited” and “voltage limited” current rating. This means that you could run this cell at 30A but must stop before it drops to 3.0V or reaches 75°C (which is pretty hot).
The two cells I tested delivered 2554mAh and 2549mAh and had DC internal resistances of 19.2mOhm and 19.5mOhm. This is fantastic consistency and both cells exceed BAK’s 2400mAh minimum and 2500mAh typical capacity ratings.
These cells were donated for testing by 18650BatteryStore (www.18650batterystore.com). Thank you!
Full Test report: https://bit.ly/3u8vs1F
I want to work for the community full time! If you feel what I do is worth a couple dollars a month and you would like early access to battery availability, battery and charger testing and news, and a say in what I test, then please consider becoming a patron and supporting my testing efforts: Battery Mooch is creating battery and device tests | Patreon.
These tests only note the ESTIMATED ratings for these batteries at the time I tested them. Any battery that is not a genuine Samsung, Sony, Murata, LG, Panasonic, Molicel, or Sanyo can change at any time! This is one of the hazards of using “rewrapped” batteries or batteries from other manufacturers so carefully research any battery you are considering using before purchasing.
Misusing or mishandling lithium-ion batteries can pose a SERIOUS RISK of personal injury or property damage. They are not meant to be used outside of a protected battery pack and you use them AT YOUR OWN RISK. Never exceed the battery’s continuous current rating and keep the plastic wrap and top insulating ring in perfect condition.
To see how other cells have tested check out this link: https://www.e-cigarette-forum.com/forum/blog-entry/list-of-battery-tests.7436/
