first the motors will get really hot,
they will lose power as the heat rises
then you’ll smell enamel melting
then they will probably dead short the windings
depending on where the dead short is, it could be catastrophic… i.e. shorting between two phases…
will it still roll or lock up , it’s not like i could trust it anyways, im sorry i cand find my phone got lots of old pics tho , while i look for it , ill send them
I translate that to “lock up” throw you off the board. in the worst case. but maybe you stop as you smell it cooking? maybe you don’t and you take the fall.
Idk that one. shorted phase wires? can that damage the ESCs? seems like it might.
And yeah, @kook this is the thinking that gets one wanting to do jeff’s hack of thermal cutoffs start/end of 80c to 140c the long ramp slowing you down but the high cutoff preventing cutouts from noisy temp senssors…
I don’t have Temp. sensors on any of my boards… but one tends to get to know their motors… I hand check new motors and motors in general as the seasons change… I can really crank the amps in the winter, but have to scale back the amps as the summer heat comes up…
the one board I did have that had temp. sensors I added thermistors to the windings… worked really good till the switch to FW5 and all the temp sensor problems…
I simply depinned the temperature sensor from the plug… now that FW5.02 is a thing, and supposedly fixed, I might try out the new firmware… but probably not… the swap from Unity FW to VESC FW was a long and hard fought battle, and I’ll be gawd-damned if’n I’m going to open the enclosure on a working board just to repin the sensor…
I just hand check them occasionally… what could go wrong???
