Am I comparing a cheaper batter with a cheaper or are they different in size?
I think I am going to ge both set of wheels. I’m a classic longboarder and believe I prefer urethane but so many people seem to like Pnumatics so it must be fun.
The higher current output plays a role in a phenomenon referred to as voltage sag,
Cells will have a lower voltage if you pull a lot of current from them, but they bounce back once the current draw is lower.
Having high output cells means that the voltage sag will be less and the cell is able to sustain a higher voltage under load.
The samsung 30q are tried and tested and are very good cells, same with the p42a, so you cant go wrong with either one, but if you have the space and don’t mind the extra weight I’d recommend going with the p42a since they should sag a bit less.
With regards to urethane vs pneumatics, I’ve been using urethane wheels on my commuter board now for 2 years (never skateboarded before that). They work fine if you have good bike paths but they’re a bit rough on normal roads, I’ve taken them on gravel paths as well but I don’t recommend it.
I recently got a second board with pneumatic wheels and the difference is quite substantial, with the urethane wheels on my commute I started remembering where certain cracks are in the pavement and know to slow down for them, a lot of these cracks I don’t even notice on pneumatics.
The downside to pneumatic wheels are that the power consumption goes up (almost double but not quite) and that you might get flats. The difference is similar to a racing car with very stiff suspension (urethane) and a normal soccer-mom van (pneumatics). Both types have their advantages but I personally am starting to like the pneumatics more even thou I have less than 100km on them, vs ~3000km on urethane.
Awesome. I read about the problem with voltage sag but I had no idea which battery handled it better.
I will surely ho with Ben’s and your suggestion of the P42A. I really appreciate you taking your time to explain these things to me.
Need a HV ESC which are generally a bit more expensive, Spintend Ubox and Stormcore 100D are good choices for HV. Other than that, more speed = more fun
It’s Molicel. With the calculator I got a range of 60km
With 110mm thane and about half of that with Pnumatics. I know my wife and she won’t let me leave the house alone for more than two hours
