@Halbj613 I still have the code in my notes, pm me!
@rpasichnyk can only the metr CAN with sd create records when not connected to a phone or is there a way to do it on the metr pro also
Only Metr CAN. Normal Metr PRO doesnât have the storage capabilities.
metr CAN or metr CAN with sd
Metr CAN with SD module. GPS module for also recording location Iâd assume.
got a gps so dont need that
thanks
may buy or may just have to learn to remember to turn my phone on
Quick question, is there a way to enable reverse or traction control via METR? Using it on a Unity, getting a little tired of rolling past the lines and freewheeling on turns
Fuck Iâm blind
motor 1, motor 2?
That would make sense.
No, with / without regen
@rpasichnyk, is possible to load a XML file with motor/app settings with metr? I do it often with the laptop. I didnât find the option in metr app, but maybe is there.
Thanks!
Any consideration towards adding a realtime video/stats overlay like the old ESC Monitor app?
If someone goes full send with field weaking it would be cool to watch the video and stats in realtime.
Yes, I have plans for improving overlay options. Right now you can do it with VIRB Edit https://metr.at/overlay but I am thinking about a simpler solution
Hey,
I would like to use the metr with a smartwatch.
I want to get the cheapest one out there, as i would use it only for eskate.
When i look for smartwatches, the cheap ones seem to be running some generic os and not real android wear os.
Can someone reccomend me a cheap watch with realz wear os ?
Thereâs this growing pain I have noticed nowadays. Sometimes Metr app just doesnât want to even initiate the bluetooth connection. You just launch the app, board is on prior and nothing. Disconnected. Fixed by either keeping bluetooth off for at least 10 minutes and the restarting the app or sometimes requires fully rebooting the phone itself. Once it gets thru very slow âPairingâ and âConnectingâ (30+ seconds) it doesnât drop connection. Never did.
@rpasichnyk are you aware of this or could it be my phone/module dying?
APP version: 4.8.18
Module: Metr PRO
Module FW version: 5.28
I wonder if logs would even show whatâs happening? I could try to get them and upload them I guessâŚ
Yes, logs should give me some info, please collect them as described here https://forum.esk8.news/t/the-definitive-guide-to-metr-app-metr-pro/3109#headingâtroubleshooting and send to support@metr.at
