Sign me in
Preorder? I was waiting for this for months
Damn, every update on metr makes me work harder to improve telemetry & logging on my boards’ receivers PCBs. Can’t keep up with you! Nice work.
Hey mate, I saw a gif of your app using streetview instead of just a satellite image/map is that going to be a thing in the future or is it already a thing and I’m too thick to figure it out?
Drag the yellow guy to the map
Ooooo. I wasn’t aware of that feature. That’s so cool!
Now we need a play and speed multiplier button to replay the rides in street view
So hype for this.
A little update, smart BMS live indicator. You can see a green dot blink when cell voltage packets are coming to the Metr app from the BMS. Works with DieBieMS / FlexiBMS / LLT BMS. Coming in the v4.6.6
Any update on when Aus and NZ shipping is possible?
Right now, do the records log any info coming from the BMS?
@Movation no updates on Aus/NZ shipping
@Pedrodemio no BMS data in the records right now
Can relate. I just spam close <-> open by instinct now.
Yup same. Sometimes once, other times 5-6 times until it loads correctly ^^
@PixelatedPolyeurthan what’s wrong?
Hol up, I’ve purchased a metr module almost a month ago shipped to Aus and there was no indication on the website that shipping would be an issue. What’s the go?
Will send you a message
I hope this fix works, can you try? https://www.icloud.com/iclouddrive/0MYDPFioC3PpYyapfc7nZpaDw#android-arm64-v8a-release
Yup it’s gone. Tried 30+ records, not once did it happen.
AS soon as the record appears use two fingers as if zooming out, do it quickly like two times. if ytou do it within the first second the record will appear as it should
