No, Metr Pro does not need to be powered all the time. Only initially to establish connection with Metr LTE / app.
Yes, Metr Pro + SD can retrieve GPS data from the Metr LTE in this configuration.
Only 0.0.55 versions to go boys, then we can pack it all in
I already have my METR Pro (with LTE and GPS) hooked up to a DC-DC always-on. Is it OK to keep it powered this way for continuous tracking or do I need to change the way things are powered?
It’s OK! Have you tried with latest Metr LTE firmware update? It should work.
I have updated firmware and it’s been reliable ever since. Thanks for all your work!
Hi i have metr pro. Is there any way to buy metr lte or something similar for tracking?
thnx
metr is discontinued. Check out Voyage Systems: Megan and Minnie
Forgive my typical cluelessness. Can you elaborate, are you expressing an opinion? I’m asking honestly, I’m not being snarky. I use metr, but my board is in the shop because I try to kill it
It’s not an opinion. Metr was discontinued but if you read about those products they have much the same functionality and from some of the same people. It could be viewed as next-gen metr. ![]()
Thanks
We still have some Metr LTE’s left. Will add them to our shop! https://shop.voyagesystems.eu
