Maytech v2 remote
OMG Someone just cut me off !?! Lemme horn at that poor bastard 3-4 click later BEEEEEEEEEEEEEEEEEEEEEEEEEEEEEP damn he already too far lmao. I think I’ll use it for lights lol
@fastrider do you have a pic of wires soldered onto receiver? Just curious how it’s done, cause I want to do it too.
@Agnes_Maytech @Eileen
Is that the relay and will receiver work with it removed?
The receiver with that thing (relay?) is bulky and won’t fit in my enclosure.
I did the same so hope I’m allowed to help as well lol
Actually I didn’t take a photo after I unsoldered the pins but here’s it lined up anyway unless you just want to see the solder work. I can get a pic of that too if needed.
You will likely have to swap rx and tx from the labels orientation
You used pwm for control and rx/tx for telemetry?
Yeah, I want to see the solder work to see how it’s done.
I’m still learning how to solder (my attempt at swapping out XT60 for XT90 on my Unity looks rough/butchered), so I’m really wary of doing any kind soldering.
I noticed you have different connector plugging into the Unity. What kind of connector is that? JST PH something something? The connectors that come with the remote don’t plug into the Unity securely, still loose.
Correct, those are just single jumper wires I use for quick testing. I used a full 6 pin jst terminal on the unitiy and just unpinned all the unused connectors.
I just cracked my lid and realized its all double side taped tight so I would not like to undo that.
yes.
Hi @Eileen, can you explain the decision to have the relay, set up as NO, act as NC when the remote is off but the reciever is powered?
Relay gone!
you forgot the pins smh :man_facepalming:t2:
No I didn’t. Haven’t gotten to it yet.
do you mean this? use the relay switch as safety switch
What a beautiful open enclosure I got here
Hope the vx2 receiver wont interfere with the maytech antenna…
:triumph: my UNUSED FLIPSHIT 6.6 is already dead wtf one works but not the other like wtf??? I plugged it in once or twice before but now only one side is working
@Eileen or @Agnes_Maytech,
Can you please provide an stl or step file for the remote housing?
Trying to turn my remote into a portal gun for Halloween :rofl:
I have a model of the screen taper that I could make work with some testing but an overlap cut would be much faster and cleaner.
Solid graphic assist! This exactly.
Do you have any images of the FSESC? i had this issue with an non-ridden fsesc and it turned out i had shorted my 5v pin with some solder to ground at the PPM pin, took that away and my issue was sorted.
