Finally had time to work on it more after the holidays, relatives coming over, vacation, etc are over.
Started programming the VESC yesterday and I have a few questions. @mishrasubhransu @BillGordon If you guys can help that’d be much appreciated!
(Screenshots of my settings are below)
My current setup:
elofty 58kv direct drives
120mm cloud wheels
makerx dual esc
I want to run it in BLDC mode
They are connected via internal canbus (I think?). It is NOT split ppm
- Is “current Hyst reverse with brake” correct? [Screenshot 1]
- Where do I limit the reverse erpm? Right now my “reverse” mode is still at full speed. I tried changing “max erpm for direction switch” [screenshot 1] but it is still reversing in full speed.
- What should my erpm be if I wanted max ~5km/h? [screenshot 7]
Does this apply in BLDC mode as well? I tried to change the “minimum erpm” from 150 to 4,000 and 10,000 but the motors made screetching sounds and didn’t work. [screenshot 5]. Am I changing the wrong thing?
Does this VESC act like it’s programming two esc’s over canbus? (It seems so from the above tests and it says its over canbus) Do I put 60a or 120a for motor max? [screenshot 3]. I want 60a/-60a max per motor.
right now I am using a temporary RC car remote until I have my VX1 setup later. When I turn the remote off, the motor goes full speed! :o Is there a way to make it “disconnect” at 0% throttle? Or is it a remote/receiver issue and it’ll be fixed when I install the VX1 remote?
Thank you so much for your help. This is alot more technical than programming a single belt 4.12 I did a while ago, and its all getting a bit over my head.
Thanks!
Screenshots:
