SALE
@YUTW123 Do you have stls for 3D printed cases for these?
Sorry, there is no cover file.
Maybe you can design one yourself.
Circuit board 3d files can be provided.
Can you pls provide a picture of the following VESC:
Go-FOC HI300(based on 75300 hardware)
Voltage: 75V maximum (recommended within 16S)
Current: 300A continuous, maximum 400A
Its the one in the picture above.
So it’s looking exactly like the HI200?
It’s the same thing
So there is no difference between the HI200 and the HI300? The 300 is $10 cheaper, which is odd. You also used to have the HI100 in a similar layout to the HI200 and HI300, is that no longer available since you have the square HI100?
Also, cool, the smaller/squarer HL100 is only $165 now, if I buy another one, will the 5v on the sensor port work on that one?
So the 100v version, is actually only for 20s according to your site ?
Yes, it can support 20s
5v output at comm port, hall port and ppm port
@YUTW123 When are you coming out with an esc that has an IMU and supports over 12S?
I’m not aware of any plans they have to produce an esc w/ an IMU. Could be cool tho.
But a fully charged 20s battery is 84v… So when you write 100v I think its a little misleading
its not misleading when it is able to handle 100v, this is the the same that goes for other esc. its headroom incase of voltage spike.
theoretically, u can even run 23s with HV200 (or trampa 100/250 or stormcore 100d) without it exploding if u have the balls. its just their way of keeping user safe to say the esc officially support 20s and below. if u want to use it for higher s count, its at ur own risk.
Do you have a custom FW for the 100/250?
It worked well with 5.0 but it gets errors with 5.1 and I can’t update to 5.2. Otherwise I need to downgrade and stick with 5.0.
5.2 The firmware works well on my side…
Talk to you in PM…
Anyone know ERPM limits for these?
