I just want to share my experience with the Retro esc from Maker X.
I’m not gonna lie, it’s a very good esc (and I mean really good. It gets me up a 45% hill with hub motors.) But, I may need to let those who are a bit inexperienced in making connectors and changing pin connectors. I do recommend having a bit of knowledge when working with this esc.
This pin is easy to work with. All you need is a pocket knife and just slide the blade into the flab and fold outwards, then pull the wire. It will come out with ease.
So for my build, it is a 10s10p battery running semi AT hub motors. The hub motors has a 5 pin hall sensor, while the Maker X retro has 6.
The company does give you a bag of connectors for you to make your own. Note these things:
There is no servo connector, so get a servo connector kit like I did.
You have to make your own with a 3 pin red/white/black ph2.0 connector given in the bag. This also uses 4mm bullet connectors and does bring 6 male bullet connectors in the bag, with one xt60 connector.
If your hall sensor is only 4-5 pins, you might need to learn how to remove the 5 ph2.0 pins and replace the one that came in a bag given (I gave out how above). The white wire is a thermo sensor, so if your hub motor doesn’t have one, you can remove it.
This is a dual ESC.
Note about updating this firmware:
Firstly, go to the bootloader tab and install the bootloader. Once you do that, your esc should now be able to accept the latest firmware. You can confirm this by looking at the name of the esc. When you first get it, it will say COM 3. Trial and error until I figured this one one out…
After updating, it will now say COM 4. Congrats, you are now using the latest firmware!
Testing this esc on my build (35amps per motor), I have to say that this esc is 100% worth it. Going up a hill, this esc will push you incredibly fast due to its amp burst. When I say fast, I mean it. I actually had to buy a helmet for the first time of my life.
If you are thinking twice about this esc, you do not have to. However, do note the maximum continuous in the website. If its too low for you, don’t get it. This was worth it for my build. Also, if your remote is the torqueboard mini, you will regret it. Get anything else but that…
So if you enjoy learning how to create your own connectors, then this esc is worth it. More info on this website.
