My wallet wants to kill you
I really want to buy one! But I donāt really needed itš Some of you can relate. We buy so many parts donāt even used it. Wait!!!.. If on sale I might buy couple. My wallet screaming NO!!!
Are they any good come on folks give feedback on a new esc help the community out.
Are the connectors on these non-standard like the first minifoc?
The same port as mini focā¦
So do these come standard with those jst adapters?
yes right
Trying to set these up right now but they wont allow firmware change!?? I donāt have the vesc tool for fw 3.63, what can I do? @YUTW123
You should be able to overwrite the bootloader/FW w/ another VESC. I just started looking into this for an old maytech VESC, but it seems like it would work for these as well.
Thanks bruddah
I also remember this. I think i just flashed the primary bootloader and then updated the new firmware.
It was possible to fix without a separate vesc
Correct, I needed to update the bootloader for mine. In the vesc tool there on the firmware section there is a bootloader tab. Its the same button used to update the firmware just on the bootloader tab
Good to know if I ever need to update fw. I went with easiest solution and used the vesc tool iteration for fw on escs that Mike shared above
Which bootloader? I would assume it is the ā60 & 75_300ā since it is vesc 6 hw.
This is in VESC tool 1.13 btw
Yep, you match it to the HW version
Do we have anyone in here that has done extensive testing on these? @BillGordon
I am wondering the same thingā¦looks like Iāll pull the trigger for science.
I finally managed to test my dual Mini FOC plus, for now only on the bench. Had to update/flash the bootloader first, after that the actual FW update went through. At first it didnāt properly write the FW on reboot. Got everything working with Metr Pro and VX1 receiver over PPM. One thing is a bit strange, I never had it happen before: When I go full throttle, the amperage goes negative.
I canāt test it on the road, have to build covers first.
Mine does that as well. I guess its a feature.
