My first build. Not complete yet, but already riding it with some duck tape. Took me a looong time to figure out what to build, what parts to order and where to order. For that reason I will share few links.
The minimum requirement is that I should be able to ride to work and back, 5.5km in one direction. But anything above 25km range is great.
Deck
Madrid from same skateshop final sale. My first and only longboard.
Motors
2 x Flipsky 6354 190KV 2450W
Bluetooth
Flipsky bluetooth module
Wheels
97MM 78A WHEEL
BMS
Charge only
Remote
HK-GT2B
Charger
My wife’s M365pro charger
Motor mounts
Not so happy with these
Updated to whooshboars mounts
Pulleys and belts
12T motor, 36T wheel, and 5M250 12mm belt
Trucks
Caliber II 184MM 50° in great colors
Changed back baseplate to 44°
Battery
Samsung 30q 3000mAh batteries
10s4p from 5 x 2s4p modules.
XT60 connectors for connecting modules in series.
JST balance wire connectors.
3D printed holders by @Winfly.
Flat tinned copper braid 6 mm2 (10 mm wide x 1 mm thick) 63 Amp from copperbraid.co.uk
Battery was the hardest part. I almoust bought a spot welder but then I realized that I will probably mess up something first time and decided to go without welding. Later I had one P group out of balance and I was so happy that I could just pull out connecors and discharge that group manually to the same level as other groups. On down side my board is small and this takes a lot of space. Plus I am woried about balance cables that might get damaged from vibrations.
XT90S Loopkey.
Fuses
Fuse on B- Auto fuse midiOTO 100A 58VDC
Charging fuse still not added.
Case is some few eur flower pot plate attached with duck tape. It almost fits. Something like this just few cm smaller.
TODO
- Charging fuse. Done
- Secure motor mounts better or change them. Original pointy set screws dug holes my trucks and then started moving. Replaced 3 of 4 but the last one is stucked and destroyed. My belts are eaten by wheels a bit but still ok. Done
- Make an enclosure. 3d print to use most of the narrow part of board + flower pot?
- Check Vesc settings. First few rides I had to big current limits for my battery, but no damage. I think. Done
- Split truck angles.. Done
- Mod GT2B remote to something smaller?
- use some fishpaper around P groups? Shrink wrap batteries.
And few more images from the process:
Battery, esc, bms schema
Some cushioning layers
Battery building
Pro tip: Look at few how to solder videos with wife to get some helping hands!
