True that that the motor will give you the same output with higher current but that works jus tin theory. In the reality you will get a pretty inefficient motor, that will sucks a lot of current and drain your battery. In my experience, Kv in direct drive matters more than gear drive since you can not compensate with the ratio. I have use 130Kv motors as direct drive and of course they work but not even close in comparison with efficiency and performance of the lower Kv one. You will most of the time stop and accelerate. The too things where they will suck, braking and torque.
You can find custom Kv motors for 50-60 each btw.
Concerning the clearance I do not know which diameter you set for the the current wheel pulley but you want to add a sleeve around the thin aluminium can of the brushless motor so a 69mm diameter is the minimum you will get with a 63mm motor to have a decent protection. That is the MAD Storm and the wheels there are 90mm… 85 is possible but you will scratch it really really easy.
It may be, I never tested the same motor in different Kv’s, if it’s not exactly the same motor with the same cooper mass it can’t be compared
I say it doesn’t matter because lets say you get a 200 Kv motor with 10 mOhm resistance, if you rewind it for 100 Kv you will need half the amount of current to produce the same torque, but the motor resistance is multiplied by 4, since the cooper loses are I²R, the cooper loses in the motor are the same for both Kv
In my testing with the direct drive simulator, doing my usual routes, the consumption was only 5% than a geared setup
I was planing to run without any sleeve, in my current board the motors already sit a little higher than they will with the direct drive, the can is surely beat up, but nothing broke
I know the ratio, just say that real application is what matters and in my experience balance before hand Kv base on the setup works better than just provide more current. Same motor, in the 130Kv version was draining my battery in 13km. In wye I go over 22km no problem. Never drained completely. Of course they both perform on paper, but I empirically experienced significantly different performance.
you might want to check the original thread on the other forum. I have posted so many pictures that everyone can make his own version
Anyhow hanger is 12mm, hole and grub screw to secure it to the central part of the truck.
the losses in the controller would be 4 times higher if you double the kv and double the current for the same torque at the same rpm, even though in theory the losses in the motor would stay the same
not in my case unfortunately, I couldn’t because I was hitting all the limits set in the VESC for motor and battery. That things was demanding so much current. Most of the losses was for the hills. Probably at constant moderate speed would have been fine. But in the city is was pulling too much to perform less than its 75Kv version.
believe me find motors around 70Kv and you will be happy about it. You will have to put quite some work to modify it. 190Kv direct drive is just not good, even at high current. Brakes must be weak too
If they turn out to be bad I will hand rewind them, I need to practice for a future project
But you are right about brakes, using only regen and shorting the coils, at low speed there were almost no brakes, them I changed to active brakes and it worked perfectly
I also use active braking because that is a known issue of direct drive, but above 5kmh the brakes are good with lower Kv motor. Anyhow good luck and make sure to post pics about it
