I have a buddy trying to set these drives up on a set of TB 110s. Did you guys have to sand anything down to get a good fit? Seems like an unnecessarily amount of force is required to seat them.
These are a new set of 110s so should not have flipped cores.
I have TB110s and a set of these drives in my workshop, I’ll try to get the adapter in the wheel today and see how much force is needed if you don’t get an answer anytime soon. From what I remember a lot is required since it is press fit.
If you look inside the spoke holes, there is a seam. That seam should be closer to the inside on a regular core, and closer to the outside on a flipped core. So either 30% of the way out, or 70% of the way. The holes themselves are slightly tapered, and that’s the skinniest point.
@Static just checked, and I was able to get the drive adapter in my TB110s probably about 70% in before a considerable amount of force was required. Didn’t put it all the way in as I still need to assemble my set
