Me!
I want to be able to fit dual 6385 motors and AT wheels.
Me!
if u r using customized pulley, how many of different t-count pulleys have u made? and if u have both kegal and abec? (im assuming here that u will use the abec clone version which can make it fit on both abec core)
what size are those wheels? and will they mount front and reverse?
The eccentricity of the ABEC core is closer to the inside than the OT wheel, I am not sure if it can be installed.
85MM boosted original wheels.The same core of kegal.
Because this can modify the bridge without damage. If someday you donāt want to play electric skateboard anymore. Then you can remove both the bracket and the pulley and use them as ordinary trucks.![]()
can the mounts be set so the motors are on the other side of the kingpin?
@YUTW123 I have already asked this before but you havenāt answered. So let me try one more time.
Are the axles threaded in? And if yes, whatās the thread size? What Iām after is if we could use your hangers with BN axles.
Can not. Turning over will block it. Unless the motor frame is lengthenedā¦
Is screwed in. 8MM shaft, the end is M8 thread.
Thanks. The part of the axle inside the truck is 8mm too or is it thicker?
For example, like a half-toothed M8 screw.
I see. Thanks. I guess no BN axles then. Thatās a shame.
They are for sale now.
so if I want to use these with my own motors and with Caguamas what wheel pulleys can I use?
I donāt see you have any for sale?
I canāt just use the push on Boardnamics I normally use with the axle length you have correct?
these look great by the way!!!
They can use Caguamas wheel. Because the core is the same.
@YUTW123 There seems to be a lot of interest in longer axles. Since the truck is modular and it seems it would be easy to replace the axles, do you plan to make and offer longer axles? Or are you afraid they would be prone to bending if longer?
If itās 8mm axle with an M6 thread you might be able to use a BN axle, I would assume thereās loctite in there though so you might have to bake it
