I’ve got a Lycaon GR skateboard inherited from a relative, and thinking using motors+battery+controller to other things. (E-bikes / kids go-kart) my problem is how do get power from motor to axle can i use “cloudwheels” Cable to motor goes through axle so cant just hold wheel and let axle spin??
or is it a better/cheaper way ?
i have no skateboard skills but been doing Computer/phone repair & electronics for years.
want to do something fun whit it
if i send power to motor blue wheel spins. if i hold down blue wheel. green axle spins.
if i add axle too blue wheel then it feels like easiest way get spinning torque.?
this is the normal motor > power > axle spins… add sprocket chain etc.
my motor > power > wheel spins. i cant add sprocket & chain to axle. so add axle to wheel it should work?
was thinking if there is any hardware 5 hole 70mm plate that i can add and get a axle on other side ?
You want to ride with cloudwheels, right ?
Well you can, without some fuckery elsewhere, just get 2 normal wheels and 2 cloudwheels sleeves !!! Have you seen my link ?!
Yes seen your link… i’m trying to go as cheap as possible. just losing whole point if i buy motors if i already have motors.
was more starting this thread because i have zero knowledge about skateboards…
needed to think and got it
