You have link to those? Can’t find them… How’s the thread pattern look
So after talking with the @kook i realized the clever 6x2 tires are way different to what most people use, and in fact not standard.
What would you guys rather have
- clever 6x2 tire (chinese/sixshooter size)
- Same tire fit as trampa, metroboard,etc
0 voters
Man I went rounds with the sunmate rep trying to get these. Drop a Link
Mboards It was the only thing they sent at a fast rate I ordered them on Amazon but they’re in mboards
fuck mBoreds!
6 Inch 150mm All Terrain Mountain Board Wheels, Electric Skateboards, Utility Carts https://www.amazon.com/dp/B085MYXWTM/ref=cm_sw_r_cp_api_i_sKVYEb0B29GGR
that’s a pretty sweet deal, if’n ya want knock-off trampa hubs and knock-off TB tires!
here’s the science for making your hubs wider…
Definitely don’t recommend mboards to anybody I’m still waiting on them to write me back about a lemon esc
since this is your thread, I thought I’d get back on topic… consider these thoughts in making your hubs…
make one half like stock…and make two outer hubs halfs… one stock hub width, and another option of having an additional 18mm of hub width (when installed) with a bigger offset to allow wide hubs to fit on stock axles…
also consider 28mm bores for 28mm bearings and a shim to be able to use 22mm normal sk8 bearings…
Forget the shim. Make the bearing seat 9mm deep
and you can use these bearings
I like that ideer more better!! tanks moon-pie
Can do that no problem
Also things might start getting heavy with that hub design if you want to use bigger tyres…
need thinner walls maybe
Yes i have to take a look at that for sure
Also i have a nice idea for the bearing seat, im gonna add a hub cap! Will keep debree out and will look cool af!
After this i will stop though, otherwise ill never reach functional testing/production fase
I love this idea. Spinners are winners.
So did you keep the Kegel pre-drilled holes?
this is still my old design, i switched over to a 2 seperate pieces rim, where one side is completely clean and the inner has the kegel core, with a similar pattern to the janux hubs.
i will make 40 t pulleys aswell if people need them
i also stretched the hub by 5 mm and made it offset.
