One of my Flipsky motors with a D shaped shaft makes an annoying clicking sound when I’m coasting on the board. It’s not causing any problems mechanically, just making the extra noise. I’m thinking a shim might help, unsure if jbweld would be strong enough.
Im not sure it would do the trick, but is loctite 648 out of the question? Also does your grub screw go down further and temporarily solve this? If it does but doesnt hold for long try some loctite on there too!
You should use this thread, instead of making a new one.
Loctite 648 is a retaining compound, which would retain your pulley to the motor shaft without a need for grub screw. Don’t use jb-weld.
If your hex key is stripped, then try a bigger size, or hammer in a different bit. You might have to drill it out. If you can get it out just replace the grub and put some blue loctite on it.
