Depending on the materials you can also use abs slurry to secure it. This is much better for dirt and water prevention but good luck removing it if you ever decide to modify your enclosure in any way.
I didn’t know about these, very nice! Definitely more sturdy and clean than using hot glue or zip ties. Shouldn’t you put shrink tubing on the wires though? That looks like an easy point for a short circuit if you’re not carful.
West System 650 epoxy has never failed me. Make sure you mix it correctly, in even 1:1 proportions, stir three times as long as you think you should, and let it cure for 5 hours between each coat and for a FULL 48 hours after the last coat before you put any stress on it, and you’re golden. It won’t ever come apart or wiggle loose.
A 3d printed case for the Male and is what I found to be the cleanest, epoxy that on and pair it with the 3d printed loop key makes it look cleaner without the wire loop exposed
I agree on the shrink tubing, but since the solder on here is cone shaped it makes it harder to use heat shrink tubing. Also, Im not really worried about a short because there are no bare wires around, these points are fixed in place and I never work on my board while it is powered. The only thing that could happen when I short those two points is that the board turns on and nothing else.
Cheeper Keys’s when I loose them. I have lots of regular xt90’s laying around. People say they wear out fast but mine has not, just got to be pushed in 100% every time.
Also I feel it’s safer as there is less exposed contacts when the key is out.
