Loaded x Unlimited Parts to electrify any skateboard
Subject: [US Boston] Loaded x Unlimited Kit to electrify any skateboard
Includes
  • 3 Batteries
  • 1 Single battery single motor plate
  • 1 dual battery dual motor plate
  • 2 hub motors
  • 3 Blue Caguama wheels
  • Lots of hub motor sleeves in red and blue
  • 2 Remotes - 1 is parts and the other works perfectly
  • 1 Charger
  • 2 Motor Controllers
  • 1 Dummy motor controller (for when you run 2 batteries and 1 motor)
  • 1 Charger
You can use this kit to electrify any skateboard, you simply install the plate under the rear truck, mount the battery(s), mount the motor controller(s) and then mount the motors to the truck - any standard truck will work, I had them installed on Paris trucks.
Includes lots of hub motor sleeves - I got extras whenever unlimited went out of business.
2 Remotes, 1 is brand new and works perfect, the other has a broken spring and is parts only
Includes 1 charger for the batteries.
Kit was working perfectly although I have had it stored for a while now with the batteries put the sleep.
You just need trucks and a deck to electrify any board.
Price is $300 OBO.
Here is the front of the motors
Sent you a message.
Two batteries are tested as good and charging, the third is blinking red but may be recoverable
Do those batteries have any proprietary bullshit going on?
It is a really neat system with smart BMS the at connects to the app.
Yeah but is it like evolve systems where you must use the evolve bms with the evolve esc?
It’s a whole little package dude.
It’s cool. It was way ahead of its time
I am needing to try and operate and put P30Bs in there
Yeah that CAN connection between BMS and ESC tells part of the story, but not whether the BMS is absolutely necessary for the esc to function properly.
You’d likely want to reuse the bms in the event of a cell swap anyway so it’s not really a big deal i suppose.
Everything is still working beautifully… :smiley:
sent you a message Im ineterested
Is the kit still available?
yeah still available, trying to decide whether to keep it as love the look on the vanguard or let it go… :slight_smile:
I’ll take it if you’re parting ways with it. Are you able to ship?
Hi @jer006, if you’re ready to let the Loaded x Unlimited kit go, I’ll take it at your $300 asking price plus shipping to Charleston, SC 29414, and I can pay right away by PayPal Goods and Services. Two quick questions: did the third battery come back, or is it still blinking red? And if the Unlimited app still works on your phone, could you unlock top speed before it ships? Thanks!
Hi Jer, do you have any of these items available?
